Ga door naar hoofdinhoud
Lenovo ThinkPad Yoga Keyboard Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad Yoga Keyboard Replacement, Battery: stap 1, afbeelding 1 van 3 Lenovo ThinkPad Yoga Keyboard Replacement, Battery: stap 1, afbeelding 2 van 3 Lenovo ThinkPad Yoga Keyboard Replacement, Battery: stap 1, afbeelding 3 van 3
    • Flip the laptop over so the bottom is facing you.
    • Remove the ten screws using a Phillips #1 screwdriver.
    • Using the plastic opening tool, pry the bottom cover off the laptop.
  2. Lenovo ThinkPad Yoga Keyboard Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad Yoga Keyboard Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad Yoga Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Remove two screws from the battery using a Phillips #1 screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Remove the battery from the laptop.
  3. Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: stap 3, afbeelding 1 van 3 Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: stap 3, afbeelding 2 van 3 Lenovo ThinkPad Yoga Keyboard Replacement, Speakers: stap 3, afbeelding 3 van 3
    • Disconnect connectors. Use fingers to pinch and pull the connector out.
  4. Lenovo ThinkPad Yoga Keyboard Replacement, Fan: stap 4, afbeelding 1 van 3 Lenovo ThinkPad Yoga Keyboard Replacement, Fan: stap 4, afbeelding 2 van 3 Lenovo ThinkPad Yoga Keyboard Replacement, Fan: stap 4, afbeelding 3 van 3
    • Remove the two screws from the retainer for the ports using a Phillips #1 screwdriver.
    • Remove the nine screws from the motherboard using a Phillips #1 screwdriver.
    • Remove the four screws from the fan under the motherboard using a Phillips #1 screwdriver.
    • Remove the fan from the motherboard.
  5. Lenovo ThinkPad Yoga Keyboard Replacement, Keyboard: stap 5, afbeelding 1 van 1
    • Remove twelve screws from the midframe using a Phillips #1 screwdriver.
  6. Lenovo ThinkPad Yoga Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Use a spudger to pry open the keyboard panel.
    • Continue to pry until the panel is loose enough to take off.
  7. Lenovo ThinkPad Yoga Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the keyboard from the laptop.
Conclusie
Felicia McCarey
299 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021 Lid van UMass Dartmouth, Team 4-4, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G4
3 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 49
Afgelopen 30 dagen: 201
Altijd: 7,563
