Wat je nodig hebt
Flip the laptop over so the bottom is facing you.
Remove the ten screws using a Phillips #1 screwdriver.
Using the plastic opening tool, pry the bottom cover off the laptop.
Remove the two screws from the retainer for the ports using a Phillips #1 screwdriver.
Remove the nine screws from the motherboard using a Phillips #1 screwdriver.
Remove the four screws from the fan under the motherboard using a Phillips #1 screwdriver.
Remove the fan from the motherboard.
Één andere persoon heeft deze handleiding voltooid.
