Ga door naar hoofdinhoud
Lenovo ThinkPad Yoga 370 Screen Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad Yoga 370 Screen Replacement, Screen: stap 1, afbeelding 1 van 1
    • Remove rubber plugs on the lower corners of the screen
    • Unscrew screws under the rubber plugs
  2. Lenovo ThinkPad Yoga 370 Screen Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad Yoga 370 Screen Replacement: stap 2, afbeelding 2 van 2
    • Remove the four 4 mm screws along the bottom of the display.
  3. Lenovo ThinkPad Yoga 370 Screen Replacement: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, remove the tape from the display cable below the screen.
  4. Lenovo ThinkPad Yoga 370 Screen Replacement: stap 4, afbeelding 1 van 1
    • Slide the screen downwards towards the keyboard.
    • Lift the screen slowly from the frame when the screen is slid down completely.
    • The screen is still attached to the computer, do not pull away from the laptop frame until a later step.
    • Flip the screen over and lay face down on the keyboard.
  5. Lenovo ThinkPad Yoga 370 Screen Replacement: stap 5, afbeelding 1 van 3 Lenovo ThinkPad Yoga 370 Screen Replacement: stap 5, afbeelding 2 van 3 Lenovo ThinkPad Yoga 370 Screen Replacement: stap 5, afbeelding 3 van 3
    • Peel the tape off from the back of the screen, connecting the display to the device.
    • Remove the screen.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
I strongly recommend to at least unplug the battery before replacing the screen. I fried a motherboard once by manipulating a screen ribbon while the battery was still plugged in.
You should always unplug the battery before working on a device anyway.
lululock - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 88
Altijd: 2,299
