Ga door naar hoofdinhoud
Lenovo ThinkPad Yoga 260 Back Cover Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad Yoga 260 Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Back Cover Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad Yoga 260 Back Cover Replacement: stap 2, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Back Cover Replacement: stap 3, afbeelding 1 van 2 Lenovo ThinkPad Yoga 260 Back Cover Replacement: stap 3, afbeelding 2 van 2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Back Cover Replacement: stap 4, afbeelding 1 van 2 Lenovo ThinkPad Yoga 260 Back Cover Replacement: stap 4, afbeelding 2 van 2
    • Place your fingers around the edges of the cover and remove it.
Conclusie
To reassemble your device, follow these instructions in reverse order
3 andere personen hebben deze handleiding voltooid.
Daniel Fernandez
963 Reputatie
5 handleidingen geschreven
USF Tampa, Team S2-G3, Eyestone Spring 2018 Lid van USF Tampa, Team S2-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S2G3
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 23
Altijd: 2,366
