Ga door naar hoofdinhoud
Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Unplug and completely shut down your computer beforehand to reduce the risk of electric shock.
    • Flip the laptop over so you can see the bottom panel.
    • Unscrew the circled screws to detach the keyboard.
  2. Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Flip the laptop back over and open it normally.
    • Use a plastic opening tool to lift up the keyboard along the bottom edge until it is detached.
  3. Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: stap 3, afbeelding 1 van 2 Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Using a finger, push the top of the keyboard out of its holder to completely detach it.
    • Move the keyboard out of the way by rotating the far side of the keyboard towards you.
  4. Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: stap 4, afbeelding 1 van 2 Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Be gentle! These connectors are very small and can easily break off.
    • Lay the keyboard on its front.
    • Disconnect the 3 cables by pulling on the attached tabs.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Sarthak Khillon
259 Reputatie
1 Handleiding geschreven
Cal Poly, Team S14-G2, Banghart Spring 2017 Lid van Cal Poly, Team S14-G2, Banghart Spring 2017
CPSU-BANGHART-S17S14G2
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 5,550
