Ga door naar hoofdinhoud
Lenovo ThinkPad Yoga 11e Gen 6 Battery Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad Yoga 11e Gen 6 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Wearing the anti-static wrist strap will prevent a static shock from damaging the components in the laptop.
    • Disconnect the laptop from power and make sure it is completely powered off.
    • Turn the laptop facing down.
    • Loosen the eight captive screws using a JIS #0 screwdriver.
    • The screws are attached to the panel and cannot be removed.
    • Use a spudger to release the tabs securing the back case and carefully remove the panel.
  2. Lenovo ThinkPad Yoga 11e Gen 6 Battery Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad Yoga 11e Gen 6 Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the three 4.5 mm screws from the battery using a JIS #0 screwdriver.
    • Lift the battery, then use your fingernail to slide the connector out of its socket.
    • Remove the battery.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 33
Altijd: 132
