Ga door naar hoofdinhoud
Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement, LCD: stap 1, afbeelding 1 van 1
    • Start by putting on your anti static wrist strap and connecting it to a stationary and stable object, like a desk.
    • This safety strap serves as a precaution to prevent any electrical static you might have on your body from transferring to the laptop's internal components and damaging the hardware.
    • Reminder to have this safety strap on you at all times during the process
  2. Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: stap 2, afbeelding 2 van 2
    • Use a T5 screwdriver to remove the two 7.62 mm screws circled in red at the bottom of the front of the display.
  3. Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: stap 3, afbeelding 1 van 3 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: stap 3, afbeelding 2 van 3 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: stap 3, afbeelding 3 van 3
    • Heat up the iopener and apply it to all 4 edges of the display
    • Be cautious when handling the iopener as the contents are hot and follow the instructions written on the product.
    • You might need to heat up the iopener multiple times to melt the glue holding the dsoplay in place
  4. Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: stap 4, afbeelding 1 van 2 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: stap 4, afbeelding 2 van 2
    • Use the Jimmy pick knife to pry the display open all around.
  5. Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: stap 5, afbeelding 1 van 3 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: stap 5, afbeelding 2 van 3 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: stap 5, afbeelding 3 van 3
    • Finally, unplug the 2 connection points of the display from the motherboard.
    • The big port will have a silver latch that needs to be flipped up for the port to come out.
    • You can now replace the old display with the new one.
Conclusie
Onel
173 Reputatie
1 Handleiding geschreven
Gateway, Team 11-11, Gonzalez Spring 2024 Lid van Gateway, Team 11-11, Gonzalez Spring 2024
GCC-GONZALEZ-S24S11G11
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 17
Altijd: 39
