Ga door naar hoofdinhoud
Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Start by putting on your anti static wrist strap and connecting it to a stationary and stable object, like a desk.
    • This safety strap serves as a precaution to prevent any electrical static you might have on your body from transferring to the laptop's internal components and damaging the hardware.
    • Reminder to have this safety strap on you at all times during the process
  2. Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: stap 2, afbeelding 3 van 3
    • Use a T5 Torx screwdriver to loosen and remove all eight bottom cover screws.
    • If you're having issues removing the bottom cover, be sure to use the opening pick to pry the case open carefully.
  3. Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: stap 3, afbeelding 1 van 2 Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: stap 3, afbeelding 2 van 2
    • Unplug the battery from the motherboard. This will need to be done before removing the battery screws.
    • The connection point is shown circled in yellow.
    • Pull the strip out, it might require some force and wiggling.
  4. Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: stap 4, afbeelding 1 van 2 Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: stap 4, afbeelding 2 van 2
    • Remove the screws holding the battery in place. There are 5 screws that need to be removed.
    • Using the same screwdriver and bit as before, remove all the screws and keep them somewhere safe.
  5. Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the battery
    • The battery is latched on so it will require some force to pop it out.
Conclusie
David Beltran Heredia
229 Reputatie
2 handleidingen geschreven
Gateway, Team 11-11, Gonzalez Spring 2024 Lid van Gateway, Team 11-11, Gonzalez Spring 2024
GCC-GONZALEZ-S24S11G11
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 35
Altijd: 114
