Ga door naar hoofdinhoud
Lenovo ThinkPad X390 SSD Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad X390 SSD Replacement, SSD: stap 1, afbeelding 1 van 1
    • Shut down and unplug the laptop before proceeding.
    • Use a Phillips #0 screwdriver to remove the five 2.7 mm screws on the base cover.
  2. Lenovo ThinkPad X390 SSD Replacement: stap 2, afbeelding 1 van 1
    • Insert a plastic opening tool between the base cover and the chassis.
    • Slide the tool along the perimeter of the case and push down as you go to release the base cover.
    • Lift the base cover up and off.
  3. Lenovo ThinkPad X390 SSD Replacement: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use tweezers to grip the battery's motherboard plug, and pull the plug directly out of its port.
  4. Lenovo ThinkPad X390 SSD Replacement: stap 4, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the four 5.2 mm screws securing the battery.
  5. Lenovo ThinkPad X390 SSD Replacement: stap 5, afbeelding 1 van 1
    • Using your hands, remove the battery from the laptop.
    • Lift the battery up and out of its housing.
  6. Lenovo ThinkPad X390 SSD Replacement: stap 6, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the single 2.9 mm screw securing the SSD to the motherboard.
  7. Lenovo ThinkPad X390 SSD Replacement: stap 7, afbeelding 1 van 1
    • Grip the SSD, and gently pull it directly out of its port.
Conclusie
Één opmerking
I have been building computers for 15+ years, i didn't go to a fancy college but even I know this tutorial is for replacing the SSD or M.2 to be specific for a X390 laptop. this is not the ram module
Patrick Timmel - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 155
Altijd: 4,402
