Ga door naar hoofdinhoud
Lenovo ThinkPad X390 Fan Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad X390 Fan Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Turn off and power down the laptop before proceeding with the guide.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Using a Phillips #0 screwdriver, unscrew the five screws on the base cover.
    • The screws are not removable.
  2. Lenovo ThinkPad X390 Fan Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad X390 Fan Replacement: stap 2, afbeelding 2 van 2
    • Remove the base cover by inserting a plastic opening tool in between the cover and the rest of the laptop.
    • Once the tool is inserted, slide the tool along the edges of the case and push down on the opening tool to detach the case.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo ThinkPad X390 Fan Replacement, Fan: stap 3, afbeelding 1 van 1
    • Unplug the fan connector from the motherboard.
  4. Lenovo ThinkPad X390 Fan Replacement: stap 4, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, unscrew the four screws holding the heat sink to the motherboard.
  5. Lenovo ThinkPad X390 Fan Replacement: stap 5, afbeelding 1 van 1
    • Lift the fan up and out and remove it from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nick Couch
252 Reputatie
1 Handleiding geschreven
Clemson, Team 5-1, Hunter Fall 2021 Lid van Clemson, Team 5-1, Hunter Fall 2021
CLEM-HUNTER-F21S5G1
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 48
Altijd: 940
