Ga door naar hoofdinhoud
Lenovo ThinkPad X280 Fan Assembly Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad X280 Fan Assembly Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Fan Assembly Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad X280 Fan Assembly Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Fan Assembly Replacement: stap 3, afbeelding 1 van 2 Lenovo ThinkPad X280 Fan Assembly Replacement: stap 3, afbeelding 2 van 2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Fan Assembly Replacement, Fan Assembly: stap 4, afbeelding 1 van 2 Lenovo ThinkPad X280 Fan Assembly Replacement, Fan Assembly: stap 4, afbeelding 2 van 2
    • Using the Phillips #1 screwdriver, loosen the four captive screws attached to the heat sink until a small pop sound heard.
    • The screws do not come all the way out and remain partially attached to the heat sink.
  5. Lenovo ThinkPad X280 Fan Assembly Replacement: stap 5, afbeelding 1 van 2 Lenovo ThinkPad X280 Fan Assembly Replacement: stap 5, afbeelding 2 van 2
    • Using the black spudger, gently push out the gray plastic connecter from the plug.
  6. Lenovo ThinkPad X280 Fan Assembly Replacement: stap 6, afbeelding 1 van 1
    • Loosen and remove the fan.
Conclusie
Jordan Wooten
594 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 79
Altijd: 2,205
