Ga door naar hoofdinhoud
Lenovo ThinkPad X260 Back Cover Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad X260 Back Cover Replacement, External Battery: stap 1, afbeelding 1 van 2 Lenovo ThinkPad X260 Back Cover Replacement, External Battery: stap 1, afbeelding 2 van 2
    • Make sure that the device is unplugged and turned off.
    • Flip the laptop from the front to the back.
  2. Lenovo ThinkPad X260 Back Cover Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad X260 Back Cover Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad X260 Back Cover Replacement: stap 2, afbeelding 3 van 3
    • Start by pinching the switches on either side of the battery outwards.
    • At the same time push the external battery, located in the back, upwards.
    • Remove the external battery from the laptop.
  3. Lenovo ThinkPad X260 Back Cover Replacement, Back Cover: stap 3, afbeelding 1 van 3 Lenovo ThinkPad X260 Back Cover Replacement, Back Cover: stap 3, afbeelding 2 van 3 Lenovo ThinkPad X260 Back Cover Replacement, Back Cover: stap 3, afbeelding 3 van 3
    • Loosen the eight 4.2 mm screws holding the back cover on using a Phillips #1 screwdriver.
    • These screws should be held in place by a small plastic washer which secures them to the cover and should not be loosened. This is illustrated in the third image.
  4. Lenovo ThinkPad X260 Back Cover Replacement: stap 4, afbeelding 1 van 3 Lenovo ThinkPad X260 Back Cover Replacement: stap 4, afbeelding 2 van 3 Lenovo ThinkPad X260 Back Cover Replacement: stap 4, afbeelding 3 van 3
    • Gently pull the cover off and set aside.
    • An iFixit opening tool may make it easier to gently remove the cover.
Conclusie
Alexander Webb
193 Reputatie
2 handleidingen geschreven
IUPUI, Team 1-3, Harley Summer 2023 Lid van IUPUI, Team 1-3, Harley Summer 2023
IUPUI-HARLEY-SU23S1G3
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 36
Altijd: 270
