Ga door naar hoofdinhoud
Lenovo ThinkPad X140e Speakers Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad X140e Speakers Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Set the laptop facing you with the screen open.
  2. Lenovo ThinkPad X140e Speakers Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad X140e Speakers Replacement: stap 2, afbeelding 2 van 2
    • Using a small plastic opening tool, pry off the keyboard starting at a point closest to you and working around the perimeter.
  3. Lenovo ThinkPad X140e Speakers Replacement: stap 3, afbeelding 1 van 3 Lenovo ThinkPad X140e Speakers Replacement: stap 3, afbeelding 2 van 3 Lenovo ThinkPad X140e Speakers Replacement: stap 3, afbeelding 3 van 3
    • Flip up the ZIF connector that is holding the small ribbon cable in place.
    • Proceed to pull out the small ribbon cable
  4. Lenovo ThinkPad X140e Speakers Replacement: stap 4, afbeelding 1 van 3 Lenovo ThinkPad X140e Speakers Replacement: stap 4, afbeelding 2 van 3 Lenovo ThinkPad X140e Speakers Replacement: stap 4, afbeelding 3 van 3
    • Flip up the ZIF connector that is holding the larger ribbon cable in place.
    • Proceed to pull out the large ribbon cable.
  5. Lenovo ThinkPad X140e Speakers Replacement, Speakers: stap 5, afbeelding 1 van 1
    • Flip the laptop upside down such that the battery would be facing away from you.
    • Remove the two 3mm Phillips #0 screws in the back located on either side of the battery.
    • Back panel and battery removal are not necessary for completion of this guide.
  6. Lenovo ThinkPad X140e Speakers Replacement: stap 6, afbeelding 1 van 2 Lenovo ThinkPad X140e Speakers Replacement: stap 6, afbeelding 2 van 2
    • Flip the laptop right-side up and open it so that the screen is facing you.
    • Pry off the front panel using a small plastic opening tool starting at a corner and working around the perimeter
  7. Lenovo ThinkPad X140e Speakers Replacement: stap 7, afbeelding 1 van 2 Lenovo ThinkPad X140e Speakers Replacement: stap 7, afbeelding 2 van 2
    • The speakers are located on the bottom of the laptop, where the mouse pad is located.
    • Remove the four 4.5 mm Phillips #0 screws on either side of both speakers.
  8. Lenovo ThinkPad X140e Speakers Replacement: stap 8, afbeelding 1 van 3 Lenovo ThinkPad X140e Speakers Replacement: stap 8, afbeelding 2 van 3 Lenovo ThinkPad X140e Speakers Replacement: stap 8, afbeelding 3 van 3
    • Remove the cable that is attached from the speakers to the board.
    • Unhook the black wire that connects the speaker on the left to the speaker on the right.
    • After unhooking the wire, simply pull the speakers out of the laptop.
Conclusie
Dylan Halland
318 Reputatie
2 handleidingen geschreven
Cal Poly, Team 20-5, Livingston Fall 2016 Lid van Cal Poly, Team 20-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G5
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 31
Altijd: 2,877
