Ga door naar hoofdinhoud
Lenovo ThinkPad X140e Battery Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad X140e Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off your laptop and unplug the charging cable.
    • Failure to remove the charging cable may cause electric shock.
    • Flip the laptop upside down.
    • Rotate the laptop so that the battery is facing away from you.
  2. Lenovo ThinkPad X140e Battery Replacement: stap 2, afbeelding 1 van 1
    • Push the first switch on the left to the right until you hear a click. This means the battery is unlocked and can be removed.
  3. Lenovo ThinkPad X140e Battery Replacement: stap 3, afbeelding 1 van 2 Lenovo ThinkPad X140e Battery Replacement: stap 3, afbeelding 2 van 2
    • Push the second switch on the right to the right, hold it there with your right hand and continue to the next step.
    • While holding the right switch open, take your free hand and pull the battery out.
Conclusie
Dylan Halland
318 Reputatie
2 handleidingen geschreven
Cal Poly, Team 20-5, Livingston Fall 2016 Lid van Cal Poly, Team 20-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G5
4 Leden
5 handleidingen geschreven
Één opmerking
I did this, but the computer says that the battery is not genuine, and then refuses to charge the battery. What do I do?
Justine Akehurst - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 965
