Inleiding
The motherboard is the central hub of communication between all of the components in your device. If one or more components are failing in your device, it may be time to replace the motherboard. Use this guide to replace the motherboard in your laptop.
Wat je nodig hebt
Flip the computer over so the bottom is facing up.
Remove nine 4mm Phillips #1 screws from the bottom of the computer.
Use an iFixit opening tool to pry the back cover off of the laptop.
Lift the plastic black strip cover that's laying over the battery connector.
Use the iFixit opening tool to flip up and disconnect the black battery connector from its motherboard socket.
Gently pull the connector away from the battery to pull it out of the slot.
Gently peel back the black plastic covering.
Remove the single Phillips #1 screw securing the wireless chip in place.
Remove the single 2mm Phillips #1 screw from the hard drive's silver casing.
Using the iFixit opening tool, flip up the eight small covers from the cable connectors.
Gently pull the cables out of the slots.
Één andere persoon heeft deze handleiding voltooid.
