Ga door naar hoofdinhoud
Lenovo ThinkPad X1 Extreme Speakers Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad X1 Extreme Speakers Replacement, Back Cover: stap 1, afbeelding 1 van 3 Lenovo ThinkPad X1 Extreme Speakers Replacement, Back Cover: stap 1, afbeelding 2 van 3 Lenovo ThinkPad X1 Extreme Speakers Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Speakers Replacement, Speakers: stap 2, afbeelding 1 van 1
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Extreme Speakers Replacement: stap 3, afbeelding 1 van 1
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
Conclusie
Kristen Gismondi
85.254 Reputatie
215 handleidingen geschreven
iFixit Lid van iFixit
Staff
140 Leden
18.086 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 373
