Ga door naar hoofdinhoud
Lenovo ThinkPad X1 Extreme RAM Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: stap 1, afbeelding 1 van 3 Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: stap 1, afbeelding 2 van 3 Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme RAM Replacement, RAM: stap 2, afbeelding 1 van 1
    • Use an opening tool to unlatch the silver gate on the side of the RAM by pushing it away from the component.
    • Repeat the same process to the other side of the RAM.
  3. Lenovo ThinkPad X1 Extreme RAM Replacement: stap 3, afbeelding 1 van 1
    • Gently grab the RAM and slide it up and away from the connector at the bottom of the component.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 1,005
