Inleiding
This Lenovo ThinkPad X1 Extreme Camera Replacement guide is useful if the camera can’t see clearly or it’s broken.
This guide requires you to remove the battery first, then unscrewed the hinges and take off the display. In the end, detach the wire connecting to the camera and remove it.
Wat je nodig hebt
Orient the laptop so that it is bottom up, and the trackpad is closest to you.
Unscrew the seven captive screws with a Phillips #00 screwdriver.
Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
Remove the back cover from the device.
Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
Use tweezers to peel the plastic cover off the connector.
Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
Gently take off the cover of the hinge of the computer with a combination of the opening tool and your hands.
