Inleiding
In the guide you will learn how to remove and replace the thermal fan assembly in the Lenovo ThinkPad X1 Carbon 7th Gen.
Damage to the computer can cause the fan to stop working, causing the computer to over heat, risking damage to the other components.
Before attempting any guide, ensure you shutdown and unplug your device.
Wat je nodig hebt
Use a Phillips #1 screwdriver to loosen the five captive screws securing the back cover.
Insert an opening pick at a 45Ëš angle between the back cover and frame near the rear middle screw.
Pry up on the pick to release the clips securing the back cover to the frame.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Use tweezers or your fingers to peel back the plastic shield covering the battery connector.
Use the flat end of a spudger to pry up on and disconnect the battery cable.
Grab the thermal fan assembly connector with your fingers and gently pull upwards to disconnect it from the motherboard.
4 andere personen hebben deze handleiding voltooid.
