Ga door naar hoofdinhoud
Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement, Back Cover: stap 1, afbeelding 1 van 2 Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
    • The screws do not completely come off from the back cover. Loosen until the screws are completely loose.
  2. Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement: stap 2, afbeelding 2 van 2
    • Use a Jimmy to lift the cover directly up off of the locating pins.
    • Though a metal opening tool is shown in the image, we recommend using plastic opening tools to minimize any cosmetic damage.
    • Remove the back cover.
    • If you encounter resistance when lifting the cover, revisit the screws to see if any of them are still threaded on to the device.
  3. Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement, SSD: stap 3, afbeelding 1 van 2 Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement, SSD: stap 3, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the single screw that secures the SSD to the motherboard.
  4. Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement: stap 4, afbeelding 1 van 1
    • Carefully remove the SSD by lifting it and pulling it out of the pins towards the battery of the laptop.
  5. Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement: stap 5, afbeelding 1 van 2 Lenovo ThinkPad X1 Carbon 6th Gen SSD Replacement: stap 5, afbeelding 2 van 2
    • Carefully peel the thermal pad off of the back of the SSD.
    • If the thermal pad is in good shape, you can reuse it by applying it to the replacement SSD.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Michael Megna
1.361 Reputatie
7 handleidingen geschreven
Cal Poly, Team S19-G4, White Winter 2020 Lid van Cal Poly, Team S19-G4, White Winter 2020
CPSU-WHITE-W20S19G4
3 Leden
23 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 56
Afgelopen 30 dagen: 351
Altijd: 22,834
