Ga door naar hoofdinhoud
Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: stap 2, afbeelding 1 van 1
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: stap 3, afbeelding 1 van 1
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement, Wi-Fi Card: stap 4, afbeelding 1 van 1
    • Use the Phillips #1 screwdriver to remove the 1.2 mm screw that's holding the Wi-Fi card in place.
  5. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the white and black coaxial antenna cables from the Wi-Fi card.
  6. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: stap 6, afbeelding 1 van 2 Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: stap 6, afbeelding 2 van 2
    • Slide the card out to remove it from the laptop.
Conclusie
Diego Garcia reyes
493 Reputatie
5 handleidingen geschreven
Gateway, Team 1-3, Saknee Fall 2021 Lid van Gateway, Team 1-3, Saknee Fall 2021
GCC-SAKNEE-F21S1G3
4 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 46
Altijd: 926
