Ga door naar hoofdinhoud
Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: stap 2, afbeelding 1 van 1
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement, Battery: stap 4, afbeelding 1 van 2 Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement, Battery: stap 4, afbeelding 2 van 2
    • Use the Phillips #1 screwdriver to remove the four 1.2 mm screws that secure the battery.
  5. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: stap 5, afbeelding 1 van 3 Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: stap 5, afbeelding 2 van 3 Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: stap 5, afbeelding 3 van 3
    • Remove the battery using your hand or a prying tool.
  6. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement, CMOS Battery: stap 6, afbeelding 1 van 1
    • Once the battery is removed the CMOS battery will be exposed.
  7. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: stap 7, afbeelding 1 van 2 Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: stap 7, afbeelding 2 van 2
    • Disconnect the CMOS cable from the socket on the motherboard.
  8. Lenovo ThinkPad X1 Carbon 5th Gen CMOS Battery Replacement: stap 8, afbeelding 1 van 1
    • Remove the CMOS battery.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Diego Garcia reyes
493 Reputatie
5 handleidingen geschreven
Gateway, Team 1-3, Saknee Fall 2021 Lid van Gateway, Team 1-3, Saknee Fall 2021
GCC-SAKNEE-F21S1G3
4 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 29
Afgelopen 7 dagen: 166
Afgelopen 30 dagen: 810
Altijd: 19,018
