Ga door naar hoofdinhoud
Lenovo ThinkPad X1 Carbon 5th Gen Back Cover Removal
Wat je nodig hebt
  1. Lenovo ThinkPad X1 Carbon 5th Gen Back Cover Removal, Back Cover: stap 1, afbeelding 1 van 1
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Back Cover Removal: stap 2, afbeelding 1 van 1
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Back Cover Removal: stap 3, afbeelding 1 van 1
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
Conclusie
If you follow these steps the back of the laptop will be exposed so you can work on other components of the laptop.
To put it back together follow these steps in reverse
Diego Garcia reyes
493 Reputatie
5 handleidingen geschreven
Gateway, Team 1-3, Saknee Fall 2021 Lid van Gateway, Team 1-3, Saknee Fall 2021
GCC-SAKNEE-F21S1G3
4 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 32
Afgelopen 30 dagen: 162
Altijd: 2,907
