Ga door naar hoofdinhoud
Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement, Battery: stap 3, afbeelding 1 van 2 Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement, Battery: stap 3, afbeelding 2 van 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: stap 4, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: stap 5, afbeelding 1 van 1
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement, USB Audio Port Board: stap 6, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the 2.9 mm screw that is holding down the USB audio port board.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: stap 7, afbeelding 1 van 2 Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: stap 7, afbeelding 2 van 2
    • Undo the clasp under the USB audio port board.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) USB Audio Port Board Replacement: stap 8, afbeelding 1 van 1
    • Remove the USB audio port board from the laptop.
Conclusie
Eevee Murdock
1.086 Reputatie
6 handleidingen geschreven
Cal Poly, Team S18-G4, White Winter 2020 Lid van Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 16
Altijd: 967
