Ga door naar hoofdinhoud
Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Battery: stap 3, afbeelding 1 van 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Battery: stap 3, afbeelding 2 van 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: stap 4, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: stap 5, afbeelding 1 van 1
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Speakers: stap 6, afbeelding 1 van 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Speakers: stap 6, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the four 4.6mm screws holding the speakers.
    • Each speaker has 2 screws.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: stap 7, afbeelding 1 van 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: stap 7, afbeelding 2 van 2
    • Disconnect the wire running from the right speaker to the motherboard.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: stap 8, afbeelding 1 van 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: stap 8, afbeelding 2 van 2
    • Remove the tape that is holding down the wire that connects the two speakers.
  9. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: stap 9, afbeelding 1 van 1
    • Remove the speakers by lifting them directly upward.
Conclusie
Eevee Murdock
1.086 Reputatie
6 handleidingen geschreven
Cal Poly, Team S18-G4, White Winter 2020 Lid van Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 1,040
