Ga door naar hoofdinhoud
Lenovo ThinkPad W541 Touchpad Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad W541 Touchpad Replacement, Touchpad: stap 1, afbeelding 1 van 2 Lenovo ThinkPad W541 Touchpad Replacement, Touchpad: stap 1, afbeelding 2 van 2
    • Slide the clips to the left and right sides, remove the battery upwards.
    • Loosen two Phillips #00 screws and open the cover plate.
    • Remove four 9.0 mm Phillips #00 case screws.
    • Remove three 9.0 mm Phillips #00 screws circled with red in the second picture.
  2. Lenovo ThinkPad W541 Touchpad Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad W541 Touchpad Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad W541 Touchpad Replacement: stap 2, afbeelding 3 van 3
    • Use the pry bar to push the keypad below the slot shown in the first picture and push it upward.
    • Loosen six Phillips #000 screws circled with red in the second picture, lift up the keyboard.
  3. Lenovo ThinkPad W541 Touchpad Replacement: stap 3, afbeelding 1 van 3 Lenovo ThinkPad W541 Touchpad Replacement: stap 3, afbeelding 2 van 3 Lenovo ThinkPad W541 Touchpad Replacement: stap 3, afbeelding 3 van 3
    • Open the black clips according to the direction marked in the first picture and remove the cable.
    • Use a pry bar to pry open the black protective casing upwards.
    • Follow the direction shown in the third picture, open the black clips upwards and remove the cable.
  4. Lenovo ThinkPad W541 Touchpad Replacement: stap 4, afbeelding 1 van 3 Lenovo ThinkPad W541 Touchpad Replacement: stap 4, afbeelding 2 van 3 Lenovo ThinkPad W541 Touchpad Replacement: stap 4, afbeelding 3 van 3
    • Remove the four 2.0 mm Phillips #000 screws circled with red in the first picture.
    • Carefully remove the metal tape shown in the second picture and paste it back on after replacing the new touchpad.
    • As shown in the third picture, remove the trackpad that needs to be replaced.
  5. Lenovo ThinkPad W541 Touchpad Replacement: stap 5, afbeelding 1 van 1
    • You can replace your touchpad with a new one. To install your computer just follow this guide in reverse.
Conclusie
Panaien Liu
121 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 18
Altijd: 365
