Inleiding
If your programs began to slow down your laptop, or programs continue to hang under load, then this guide should help you replace the RAM/Memory stick within your laptop. This guide is also helpful in the case that you need to upgrade your laptop's RAM sticks.
Wat je nodig hebt
Flip your laptop to the bottom so that the backplate is shown.
Unscrew the captive screws on the backplate with a Phillips #0 screwdriver.
Bijna klaar!
Conclusie
