Ga door naar hoofdinhoud
Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement, Optical Disk Drive (ODD): stap 1, afbeelding 1 van 2 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement, Optical Disk Drive (ODD): stap 1, afbeelding 2 van 2
    • Turn your laptop over so the backplate is facing you.
    • Start with your Phillips #0 screwdriver and unscrew the 2 screws in each of the top corners of the backplate.
    • These screws should stay put on the backplate, and should not fall off.
  2. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: stap 2, afbeelding 2 van 2
    • With your Phillips #00 screwdriver, simply remove the one 3mm screw on the upper left side.
  3. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: stap 3, afbeelding 1 van 3 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: stap 3, afbeelding 2 van 3 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: stap 3, afbeelding 3 van 3
    • Remove the ODD by using a plastic opening tool to push the drive out of the side of the laptop.
    • Make sure to place the tool where we removed the screw holding the drive in place in Step 2.
  4. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: stap 4, afbeelding 1 van 1
    • Once the ODD has popped out, simply grab and pull out the drive bay.
Conclusie
Isaac
205 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 Lid van UMass Dartmouth, Team 4-1, Shaddix Spring 2024
UMASSD-SHADDIX-S24S4G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 17
Altijd: 112
