Ga door naar hoofdinhoud
Lenovo ThinkPad W540 Display Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad W540 Display Replacement, Display: stap 1, afbeelding 1 van 2 Lenovo ThinkPad W540 Display Replacement, Display: stap 1, afbeelding 2 van 2
    • Open your laptop so that the screen is at around a 180 degree angle.
    • Using a plastic opening tool, pry open the outer frame of the display.
    • Generally, it is best practice to start from the corner first, and then guide the opening tool around the the frame.
  2. Lenovo ThinkPad W540 Display Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad W540 Display Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to unscrew the four 3 mm screws holding the display, one for each corner.
    • Once unscrewed, flip the display over the other side of the laptop (keyboard end).
  3. Lenovo ThinkPad W540 Display Replacement: stap 3, afbeelding 1 van 2 Lenovo ThinkPad W540 Display Replacement: stap 3, afbeelding 2 van 2
    • Use a plastic spudger, safety lift the adhesive tape from the connector.
    • Do not disregard the tape from the connector entirely as you will be reusing it later.
    • This adhesive tape will be strong, remove the tape carefully to prevent damage to the display connector.
  4. Lenovo ThinkPad W540 Display Replacement: stap 4, afbeelding 1 van 1
    • Safely disconnect the display from the connector.
    • Although you can use your hands to disconnect the connector, it is recommended that you use a spudger instead.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kevin Dang
333 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 3-2, Konn Fall 2023 Lid van UMass Dartmouth, Team 3-2, Konn Fall 2023
UMASSD-KONN-F23S3G2
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 21
Altijd: 136
