Ga door naar hoofdinhoud
Lenovo ThinkPad T570 SSD Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T570 SSD Replacement, Battery: stap 1, afbeelding 1 van 3 Lenovo ThinkPad T570 SSD Replacement, Battery: stap 1, afbeelding 2 van 3 Lenovo ThinkPad T570 SSD Replacement, Battery: stap 1, afbeelding 3 van 3
    • Switch the left latch to the left to unlock the battery.
    • While holding the right latch to the right, slide the battery away from the device.
  2. Lenovo ThinkPad T570 SSD Replacement, SSD: stap 2, afbeelding 1 van 3 Lenovo ThinkPad T570 SSD Replacement, SSD: stap 2, afbeelding 2 van 3 Lenovo ThinkPad T570 SSD Replacement, SSD: stap 2, afbeelding 3 van 3
    • Loosen the seven captive screws on the back panel of the computer using a Phillips #0 screwdriver.
    • The screws are designed so they do not come out of the laptop base, so twist the screwdriver until they are completely loosened.
    • Remove the back panel.
  3. Lenovo ThinkPad T570 SSD Replacement: stap 3, afbeelding 1 van 3 Lenovo ThinkPad T570 SSD Replacement: stap 3, afbeelding 2 van 3 Lenovo ThinkPad T570 SSD Replacement: stap 3, afbeelding 3 van 3
    • Pinch the black tab and pull it to the left and up to remove the SSD.
    • Flip the hinge upward and detach the piece that's connected to the SSD by pulling the tab to the left.
  4. Lenovo ThinkPad T570 SSD Replacement: stap 4, afbeelding 1 van 2 Lenovo ThinkPad T570 SSD Replacement: stap 4, afbeelding 2 van 2
    • Using the Phillips #0 screwdriver, remove the two 3 mm screws.
    • These screws are very small. Be mindful when removing them so that they do not get lost.
    • Remove the metal bracket.
    • Remove the SSD.
    • This device did not include an SSD.
Conclusie
Rylee Hjorth
277 Reputatie
3 handleidingen geschreven
Utah Tech University, Team 1-3, Crenshaw Fall 2024 Lid van Utah Tech University, Team 1-3, Crenshaw Fall 2024
UTAHTECH-CRENSHAW-F24S1G3
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 56
Altijd: 175
