Ga door naar hoofdinhoud
Lenovo ThinkPad T560 SSD/Hard Drive Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T560 SSD/Hard Drive Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
  2. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
  3. Lenovo ThinkPad T560 SSD/Hard Drive Replacement, SSD/Hard Drive: stap 3, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove the 3.5mm screw securing the SSD/Hard Drive.
  4. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Pick up the SSD/Hard Drive and unplug it from the cable connecting the SSD/Hard Drive to the motherboard.
  5. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • Remove SSD/Hard Drive case from the drive.
Conclusie
Jackson Reynolds
517 Reputatie
5 handleidingen geschreven
Clemson, Team 1-3, Hunter Spring 2022 Lid van Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
5 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 52
Afgelopen 30 dagen: 178
Altijd: 5,883
