Ga door naar hoofdinhoud
Lenovo ThinkPad T530 External Battery Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T530 External Battery Replacement, Place your laptop upside down: stap 1, afbeelding 1 van 2 Lenovo ThinkPad T530 External Battery Replacement, Place your laptop upside down: stap 1, afbeelding 2 van 2
    • Ensure that the laptop is disconnected from the wall charger, and that the laptop is entirely powered off before following any of the steps below.
    • Flip your laptop upside down, so that the keyboard is facing down.
  2. Lenovo ThinkPad T530 External Battery Replacement, Unlock Battery: stap 2, afbeelding 1 van 2 Lenovo ThinkPad T530 External Battery Replacement, Unlock Battery: stap 2, afbeelding 2 van 2
    • Locate the latch located on the battery near the top of the laptop.
    • Using your finger, slide the latch to the right-most (Unlocked) position.
    • None of this should require an exhuberant amount of force.
  3. Lenovo ThinkPad T530 External Battery Replacement, Remove the Battery: stap 3, afbeelding 1 van 2 Lenovo ThinkPad T530 External Battery Replacement, Remove the Battery: stap 3, afbeelding 2 van 2
    • You can now pull the battery away from the laptop. When pulling the battery out, ensure to pull it out straight.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Bijgevoegde documenten
Albert Stoynov
1.257 Reputatie
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 225
