Ga door naar hoofdinhoud
Lenovo ThinkPad T500 Speaker Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T500 Speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
    • Remove the eight 14mm screws using the Phillips #0 Screwdriver.
  2. Lenovo ThinkPad T500 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Lift the palm rest panel up.
    • Be sure to lift the panel slowly; there is a ribbon cable attached to the bottom.
  3. Lenovo ThinkPad T500 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Use the spudger to disconnect the ribbon cable.
  4. Lenovo ThinkPad T500 Speaker Replacement: stap 4, afbeelding 1 van 1
    • With the panel disconnected, lift the keyboard.
    • As with the panel, lift the keyboard slowly; there is a ribbon cable attached to the bottom.
  5. Lenovo ThinkPad T500 Speaker Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the ribbon cable with the spudger.
  6. Lenovo ThinkPad T500 Speaker Replacement: stap 6, afbeelding 1 van 2 Lenovo ThinkPad T500 Speaker Replacement: stap 6, afbeelding 2 van 2
    • Remove the keyboard and the panel.
    • Using the Phillips #0 Screwdriver, remove the three 3 mm screws that are at the bottom sides and near the top-left of the speaker cover.
    • Disconnect the orange and blue cables next to the left side of the speaker cover.
  7. Lenovo ThinkPad T500 Speaker Replacement: stap 7, afbeelding 1 van 1
    • Remove the speaker cover by carefully pulling up and towards you.
  8. Lenovo ThinkPad T500 Speaker Replacement: stap 8, afbeelding 1 van 1
    • Remove the four 3mm screws on the speakers with the Phillips #0 Screwdriver.
  9. Lenovo ThinkPad T500 Speaker Replacement: stap 9, afbeelding 1 van 2 Lenovo ThinkPad T500 Speaker Replacement: stap 9, afbeelding 2 van 2
    • Using the spudger, lift the tape over the right speaker's wires.
    • Although the right speaker is unscrewed, it can't be removed from the laptop yet!
  10. Lenovo ThinkPad T500 Speaker Replacement: stap 10, afbeelding 1 van 2 Lenovo ThinkPad T500 Speaker Replacement: stap 10, afbeelding 2 van 2
    • Detach the blue and orange cables from the left speaker's clamps.
  11. Lenovo ThinkPad T500 Speaker Replacement: stap 11, afbeelding 1 van 3 Lenovo ThinkPad T500 Speaker Replacement: stap 11, afbeelding 2 van 3 Lenovo ThinkPad T500 Speaker Replacement: stap 11, afbeelding 3 van 3
    • Locate the plug in the middle of the laptop that connects both the left and right speakers.
    • Use the spudger to unplug the speaker wires.
  12. Lenovo ThinkPad T500 Speaker Replacement: stap 12, afbeelding 1 van 1
    • Remove the speakers.
Conclusie
nicO
15.927 Reputatie
88 handleidingen geschreven
Global Fixers Lid van Global Fixers
Community
34 Leden
597 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 1,227
