Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Remove the speaker cover.
Per rimuovere questa parte occorre svitare altre due vito da sotto, sul lato posteriore
Yes, there is another screw or two that have to be removed from the underside of the laptop before you can remove the speaker cover.
Remove the two 3mm screws next to the lid hinges, as well as the two 3mm screws on the lid's ribbon cable.
Per rimuovere il display occorre svitare altre due vito da sotto, sul lato posteriore
6 andere personen hebben deze handleiding voltooid.
Één commentaar
It was of good help, but be aware that you need to remove two screws on the back before removing the speaker cover. If not you will break the cover.
