Ga door naar hoofdinhoud
Lenovo ThinkPad T495 Wi-Fi Card Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T495 Wi-Fi Card Replacement, Baseplate: stap 1, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 Wi-Fi Card Replacement: stap 2, afbeelding 1 van 1
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: stap 3, afbeelding 1 van 3 Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: stap 3, afbeelding 2 van 3 Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to lift the two coaxial cable connectors vertically, disconnecting them from the Wi-Fi card.
    • Use a Phillips #00 screwdriver to remove the 6 mm screw, causing the Wi-Fi card to pop up.
  4. Lenovo ThinkPad T495 Wi-Fi Card Replacement: stap 4, afbeelding 1 van 2 Lenovo ThinkPad T495 Wi-Fi Card Replacement: stap 4, afbeelding 2 van 2
    • Grip the Wi-Fi card between your fingers and pull it in the direction of the card, at a slight angle, until it releases from its port.
Conclusie
Christian Taylor
523 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 1-6, Petersen Spring 2022 Lid van UMass Dartmouth, Team 1-6, Petersen Spring 2022
UMASSD-PETERSEN-S22S1G6
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 28
Altijd: 773
