Ga door naar hoofdinhoud
Lenovo ThinkPad T495 Speaker Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T495 Speaker Replacement, Baseplate: stap 1, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 Speaker Replacement, Speaker: stap 3, afbeelding 1 van 3 Lenovo ThinkPad T495 Speaker Replacement, Speaker: stap 3, afbeelding 2 van 3 Lenovo ThinkPad T495 Speaker Replacement, Speaker: stap 3, afbeelding 3 van 3
    • Grip the speaker cable as close as possible to its motherboard plug, and pull directly backwards, parallel to the motherboard, until the plug releases.
  4. Lenovo ThinkPad T495 Speaker Replacement: stap 4, afbeelding 1 van 2 Lenovo ThinkPad T495 Speaker Replacement: stap 4, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the three 1.6 mm screws.
    • Holding both sides, lift the speaker up and out.
Conclusie
Christian Taylor
562 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 1-6, Petersen Spring 2022 Lid van UMass Dartmouth, Team 1-6, Petersen Spring 2022
UMASSD-PETERSEN-S22S1G6
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 45
Altijd: 647
