Ga door naar hoofdinhoud
Lenovo ThinkPad T495 Solid State Drive (SSD) Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T495 Solid State Drive (SSD) Replacement, Baseplate: stap 1, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 Solid State Drive (SSD) Replacement: stap 2, afbeelding 1 van 1
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 Solid State Drive (SSD) Replacement, Solid State Drive: stap 3, afbeelding 1 van 3 Lenovo ThinkPad T495 Solid State Drive (SSD) Replacement, Solid State Drive: stap 3, afbeelding 2 van 3 Lenovo ThinkPad T495 Solid State Drive (SSD) Replacement, Solid State Drive: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a Phillips #00 screwdriver to remove the 6 mm screw.
    • Use tweezers or an iFixit opening tool to lift the SSD up and away from the thermal pad it rests on.
    • Grip the SSD between your fingers and pull it horizontally to the right at a slight angle until it releases from the port.
    • The thermal pad is slightly sticky, and may stick to the bottom of the SSD as you remove it. If it does, be careful not to damage it, and make sure to reinstall the thermal pad before replacing the SSD.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Christian Taylor
523 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 1-6, Petersen Spring 2022 Lid van UMass Dartmouth, Team 1-6, Petersen Spring 2022
UMASSD-PETERSEN-S22S1G6
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 50
Afgelopen 30 dagen: 170
Altijd: 3,327
