Ga door naar hoofdinhoud
Lenovo ThinkPad T490 Speaker Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T490 Speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
    • Using a Philips #1 screwdriver, fully loosen the six screws on the back cover.
    • These screws are captive - they will not fully come out after being unscrewed.
  2. Lenovo ThinkPad T490 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Insert the iFixit opening tool into the space between the base plate and the chassis.
    • Glide the tool along the perimeter of the base plate in order to release the clips holding the base plate and chassis together.
  3. Lenovo ThinkPad T490 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Grab the edge of the cover and lift the cover away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
  4. Lenovo ThinkPad T490 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Make careful note of the location of the speaker and the battery.
    • The speaker is located in the top middle.
    • The battery is located at the bottom.
  5. Lenovo ThinkPad T490 Speaker Replacement: stap 5, afbeelding 1 van 2 Lenovo ThinkPad T490 Speaker Replacement: stap 5, afbeelding 2 van 2
    • Gently pull the pull tab in order to disconnect the battery from its socket.
  6. Lenovo ThinkPad T490 Speaker Replacement: stap 6, afbeelding 1 van 3 Lenovo ThinkPad T490 Speaker Replacement: stap 6, afbeelding 2 van 3 Lenovo ThinkPad T490 Speaker Replacement: stap 6, afbeelding 3 van 3
    • Using the Phillips #1 screwdriver, remove the three 5 mm screws from the centralized speaker.
  7. Lenovo ThinkPad T490 Speaker Replacement: stap 7, afbeelding 1 van 1
    • Locate the pull tab at the bottom right hand corner of the speaker.
  8. Lenovo ThinkPad T490 Speaker Replacement: stap 8, afbeelding 1 van 1
    • Pull the speaker pull tab in order to remove it from its socket.
  9. Lenovo ThinkPad T490 Speaker Replacement: stap 9, afbeelding 1 van 1
    • Remove the speaker from the case.
  10. Lenovo ThinkPad T490 Speaker Replacement: stap 10, afbeelding 1 van 1
    • The case should look like this after successful completion of the previous steps and safe removal of the speaker.
Conclusie
ferni fuentes
565 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 50
Altijd: 95
