Ga door naar hoofdinhoud
Lenovo ThinkPad T490 CMOS Battery Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T490 CMOS Battery Replacement, CMOS Battery: stap 1, afbeelding 1 van 1
    • Using a Philips #1 screwdriver fully loosen the six screws on the back cover.
    • These screws are captive - they will not fully come out after being unscrewed.
  2. Lenovo ThinkPad T490 CMOS Battery Replacement: stap 2, afbeelding 1 van 1
    • Insert the iFixit opening tool into the space between the baseplate and the chassis.
    • Glide the tool along the perimeter of the case in order to release the clips holding the case and chassis together.
  3. Lenovo ThinkPad T490 CMOS Battery Replacement: stap 3, afbeelding 1 van 1
    • Grab the edge of the cover and lift the cover away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
  4. Lenovo ThinkPad T490 CMOS Battery Replacement: stap 4, afbeelding 1 van 2 Lenovo ThinkPad T490 CMOS Battery Replacement: stap 4, afbeelding 2 van 2
    • Locate the battery socket connector parallel to the motherboard.
    • Slide the battery socket connector out of its socket on the motherboard.
  5. Lenovo ThinkPad T490 CMOS Battery Replacement: stap 5, afbeelding 1 van 2 Lenovo ThinkPad T490 CMOS Battery Replacement: stap 5, afbeelding 2 van 2
    • Unplug the connector from the socket on the motherboard.
    • Pry the coin cell battery off of the motherboard.
  6. Lenovo ThinkPad T490 CMOS Battery Replacement: stap 6, afbeelding 1 van 1
    • Insert new coin cell battery.
Conclusie
ferni fuentes
565 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 56
Altijd: 106
