Ga door naar hoofdinhoud
Lenovo ThinkPad T470S Batteries Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T470S Batteries Replacement, Bottom Panel: stap 1, afbeelding 1 van 1
    • Use a Phillips #000 screwdriver to remove the five 7 mm screws from the bottom of the laptop.
    • Lift the bottom panel up and off the laptop.
  2. Lenovo ThinkPad T470S Batteries Replacement, Batteries: stap 2, afbeelding 1 van 3 Lenovo ThinkPad T470S Batteries Replacement, Batteries: stap 2, afbeelding 2 van 3 Lenovo ThinkPad T470S Batteries Replacement, Batteries: stap 2, afbeelding 3 van 3
    • Remove two screws on the bottom of the upper battery using a Phillips #000 screwdriver.
    • Remove three screws on the top of the lower battery using a Phillips #000 screwdriver.
    • Peel back connecting supporting tape on each of the batteries.
  3. Lenovo ThinkPad T470S Batteries Replacement: stap 3, afbeelding 1 van 3 Lenovo ThinkPad T470S Batteries Replacement: stap 3, afbeelding 2 van 3 Lenovo ThinkPad T470S Batteries Replacement: stap 3, afbeelding 3 van 3
    • Slide the upper battery out of the device, away from the laptop.
    • Slide the lower battery out of the device, away from the laptop.
    My laptop says Battery 1 is at 0% and does not hold a charge and Battery 2 is at 88% and I have 4h 22min of estimates time remaining. Which battery do I need to replace? Upper or lower?
    Sohel Ameer - Antwoord
    You would think Lenovo would make this information readily available. Im in their manual right now. Not seeing anything. Extremely annoying. Will just use a trial and error method removing one and see if thats the defective one.
    Sean Love -
    Looks like battery 1 is the larger battery.
    Sean Love -
    If I remove battery 1 or 2 will there be any problem running my laptop?
    Saiful Islam - Antwoord
Conclusie
7 andere personen hebben deze handleiding voltooid.
3Gids Commentaar
Is the rear battery, battery 1 or 2? It's my battery 2 that won't charge any more. But maybe I should just change them both. Do you sell both of them or just the one?
Trisha Moore - Antwoord
I am facing the same issue. What have u done for this... Which battery u changed the external one or internal?
Ayesha Sajid -
Battery 1 (00HW023) is the larger of the two and sits under the track pad. Battery 2 (01AV406) is the smaller one and sits by the hinge to the screen.
Jesus Diaz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 29
Afgelopen 7 dagen: 267
Afgelopen 30 dagen: 1,122
Altijd: 38,747
