Ga door naar hoofdinhoud
Lenovo ThinkPad T460s RAM Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T460s RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s RAM Replacement: stap 2, afbeelding 1 van 1
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s RAM Replacement: stap 3, afbeelding 1 van 1
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  4. Lenovo ThinkPad T460s RAM Replacement: stap 4, afbeelding 1 van 3 Lenovo ThinkPad T460s RAM Replacement: stap 4, afbeelding 2 van 3 Lenovo ThinkPad T460s RAM Replacement: stap 4, afbeelding 3 van 3
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
  5. Lenovo ThinkPad T460s RAM Replacement, RAM: stap 5, afbeelding 1 van 3 Lenovo ThinkPad T460s RAM Replacement, RAM: stap 5, afbeelding 2 van 3 Lenovo ThinkPad T460s RAM Replacement, RAM: stap 5, afbeelding 3 van 3
    • To remove the existing RAM module, pull tabs marked in the red outwards.
Conclusie
3 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 79
Altijd: 4,708
