Ga door naar hoofdinhoud
Lenovo ThinkPad T460s Heatsink Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T460s Heatsink Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s Heatsink Replacement: stap 2, afbeelding 1 van 1
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s Heatsink Replacement: stap 3, afbeelding 1 van 1
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  4. Lenovo ThinkPad T460s Heatsink Replacement: stap 4, afbeelding 1 van 3 Lenovo ThinkPad T460s Heatsink Replacement: stap 4, afbeelding 2 van 3 Lenovo ThinkPad T460s Heatsink Replacement: stap 4, afbeelding 3 van 3
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
  5. Lenovo ThinkPad T460s Heatsink Replacement, Heatsink: stap 5, afbeelding 1 van 3 Lenovo ThinkPad T460s Heatsink Replacement, Heatsink: stap 5, afbeelding 2 van 3 Lenovo ThinkPad T460s Heatsink Replacement, Heatsink: stap 5, afbeelding 3 van 3
    • Remove the fan power cable in red square first.
    • Loosen all four 5.5mm Phillips #1 screws marked in red circle to take off the Radiator Assembly.
    • Those 4 screws can't be removed since all the screws have a retainer from the back
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 45
Altijd: 2,422
