Ga door naar hoofdinhoud
Lenovo ThinkPad T440p Display Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T440p Display Replacement, Display: stap 1, afbeelding 1 van 2 Lenovo ThinkPad T440p Display Replacement, Display: stap 1, afbeelding 2 van 2
    • Flip the laptop over so that the bottom of the laptop is facing you.
  2. Lenovo ThinkPad T440p Display Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad T440p Display Replacement: stap 2, afbeelding 2 van 2
    • Slide each of the battery latches away from each other into the unlocked location.
  3. Lenovo ThinkPad T440p Display Replacement: stap 3, afbeelding 1 van 2 Lenovo ThinkPad T440p Display Replacement: stap 3, afbeelding 2 van 2
    • Slide the battery out of the battery compartment.
  4. Lenovo ThinkPad T440p Display Replacement: stap 4, afbeelding 1 van 2 Lenovo ThinkPad T440p Display Replacement: stap 4, afbeelding 2 van 2
    • Flip the laptop over so that the top of the laptop faces you.
  5. Lenovo ThinkPad T440p Display Replacement: stap 5, afbeelding 1 van 2 Lenovo ThinkPad T440p Display Replacement: stap 5, afbeelding 2 van 2
    • Lift the lid of the laptop until the top of the lid is touching the ground.
  6. Lenovo ThinkPad T440p Display Replacement: stap 6, afbeelding 1 van 3 Lenovo ThinkPad T440p Display Replacement: stap 6, afbeelding 2 van 3 Lenovo ThinkPad T440p Display Replacement: stap 6, afbeelding 3 van 3
    • Carefully pry the display bezels away from the display using the plastic opening tool.
    • The edges on the underside of the bezel that touches the display may be sharp.
  7. Lenovo ThinkPad T440p Display Replacement: stap 7, afbeelding 1 van 2 Lenovo ThinkPad T440p Display Replacement: stap 7, afbeelding 2 van 2
    • Use the Phillips #0 screwdriver to remove the four 3mm display screws.
  8. Lenovo ThinkPad T440p Display Replacement: stap 8, afbeelding 1 van 1
    • Carefully lift the display up and place it on the keyboard.
    • Don't remove it from the laptop. There's a cable still attached to it.
  9. Lenovo ThinkPad T440p Display Replacement: stap 9, afbeelding 1 van 3 Lenovo ThinkPad T440p Display Replacement: stap 9, afbeelding 2 van 3 Lenovo ThinkPad T440p Display Replacement: stap 9, afbeelding 3 van 3
    • Locate the latch attached to the display cable.
    • Grab the latch and flip it over so that it is facing away from you.
  10. Lenovo ThinkPad T440p Display Replacement: stap 10, afbeelding 1 van 1
    • Gently remove the cable from the display by pulling it directly away from you.
  11. Lenovo ThinkPad T440p Display Replacement: stap 11, afbeelding 1 van 2 Lenovo ThinkPad T440p Display Replacement: stap 11, afbeelding 2 van 2
    • Remove the display from the computer.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Rasheed Adam
337 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G19, Cardinal Summer 2020 Lid van UW Tacoma, Team S1-G19, Cardinal Summer 2020
UWT-CARDINAL-SU20S1G19
1 Lid
1 handleiding geschreven
2 opmerkingen
Easy peasy! Got a fresh 1080p IPS display into my ThinkPad thanks to this guide!
Noah - Antwoord
What display did you have before? I have heard that there are two different display cables and if you didn't already have a 900p screen/already had a 768p screen, then you will need a new display cable to do the FHD display swap.
Annika Genisis -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 67
Altijd: 3,195
