Inleiding
The back cover is the protective layer for your computer that covers many components that will likely be replaced. The process is very simple and you will only need to remove two screws with a Phillips #1 screw driver.
Wat je nodig hebt
Use a Phillips #1 screwdriver to remove the two 9mm screws holding the back cover.
Één andere persoon heeft deze handleiding voltooid.
