Ga door naar hoofdinhoud
Lenovo ThinkPad T431S Hard Drive Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T431S Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 3 Lenovo ThinkPad T431S Hard Drive Replacement, Hard Drive: stap 1, afbeelding 2 van 3 Lenovo ThinkPad T431S Hard Drive Replacement, Hard Drive: stap 1, afbeelding 3 van 3
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect the laptop from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver to remove the eight 5.0 mm screws from the panel.
    • After loosening the screws, use the three opening tools to take the back panel off of the rest of the device.
  2. Lenovo ThinkPad T431S Hard Drive Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad T431S Hard Drive Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad T431S Hard Drive Replacement: stap 2, afbeelding 3 van 3
    • Remove the single 3 mm screw holding hard drive bracket in place.
    • Grasp the hard drive and remove it from its bracket.
    • Use a slight wiggle motion to carefully disconnect it from the front prong.
Conclusie
Één opmerking
Can I add SSD without removing HDD? in Lenovo T431s?
Usama Khan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 631
