Inleiding
This guide will show you how to locate and replace the Lenovo T431s charging port. The charging port is crucial for charging your computer’s battery. If you are experiencing charging problems, loose port, or unresponsiveness, then you may need to replace your charging port.
Wat je nodig hebt
Use a Phillips #1 screwdriver bit to remove eight 5.0 mm screws from the back panel.
After loosening the screws, use the three opening tools to take the back panel off of the rest of the device.
