Ga door naar hoofdinhoud
Lenovo ThinkPad T431S Charging Port Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T431S Charging Port Replacement, Charging Port: stap 1, afbeelding 1 van 2 Lenovo ThinkPad T431S Charging Port Replacement, Charging Port: stap 1, afbeelding 2 van 2
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver bit to remove eight 5.0 mm screws from the back panel.
    • After loosening the screws, use the three opening tools to take the back panel off of the rest of the device.
  2. Lenovo ThinkPad T431S Charging Port Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad T431S Charging Port Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the single, 3.0 mm screw with a Phillips #1 screwdriver bit that holds the charging port housing into place.
  3. Lenovo ThinkPad T431S Charging Port Replacement: stap 3, afbeelding 1 van 2 Lenovo ThinkPad T431S Charging Port Replacement: stap 3, afbeelding 2 van 2
    • Remove the small, white connector cable by prying it from the connector with a plastic opening tool.
    • Remove the charging port assembly.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 22
Altijd: 4,056
