Ga door naar hoofdinhoud
Lenovo ThinkPad T410s Palm-rest Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T410s Palm-rest Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop over.
    • Push and hold the locking switch to the left.
    • Pull the battery out with your other hand.
  2. Lenovo ThinkPad T410s Palm-rest Replacement, RAM: stap 2, afbeelding 1 van 2 Lenovo ThinkPad T410s Palm-rest Replacement, RAM: stap 2, afbeelding 2 van 2
    • Remove the single Phillips #0 screw grin the back panel.
    • Pull the back panel off.
  3. Lenovo ThinkPad T410s Palm-rest Replacement: stap 3, afbeelding 1 van 3 Lenovo ThinkPad T410s Palm-rest Replacement: stap 3, afbeelding 2 van 3 Lenovo ThinkPad T410s Palm-rest Replacement: stap 3, afbeelding 3 van 3
    • Pull the metal prongs at the side of the RAM away from each other.
    • The RAM will pop out of its socket when done correctly.
    • Pull the RAM out.
  4. Lenovo ThinkPad T410s Palm-rest Replacement, Keyboard: stap 4, afbeelding 1 van 1
    • Remove the Flathead 2.5mm screw.
  5. Lenovo ThinkPad T410s Palm-rest Replacement: stap 5, afbeelding 1 van 2 Lenovo ThinkPad T410s Palm-rest Replacement: stap 5, afbeelding 2 van 2
    • Wedge the flat end of a spudger, or plastic opening tool, under the end of the keyboard and pry up.
  6. Lenovo ThinkPad T410s Palm-rest Replacement: stap 6, afbeelding 1 van 2 Lenovo ThinkPad T410s Palm-rest Replacement: stap 6, afbeelding 2 van 2
    • Slide the keyboard out of the way until you can see what's underneath it.
    • The keyboard is still attached with a ribbon cable so don't try to fully remove it.
  7. Lenovo ThinkPad T410s Palm-rest Replacement: stap 7, afbeelding 1 van 1
    • Use the flat end of a spudger to unplug the keyboard connector from the laptop.
    • Pull the keyboard out.
  8. Lenovo ThinkPad T410s Palm-rest Replacement, Palm-rest: stap 8, afbeelding 1 van 1
    • Remove the twelve Phillips #0 screws from the back panel.
  9. Lenovo ThinkPad T410s Palm-rest Replacement: stap 9, afbeelding 1 van 2 Lenovo ThinkPad T410s Palm-rest Replacement: stap 9, afbeelding 2 van 2
    • Up the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Pull out the ribbon connector from the ZIF connector.
  10. Lenovo ThinkPad T410s Palm-rest Replacement: stap 10, afbeelding 1 van 2 Lenovo ThinkPad T410s Palm-rest Replacement: stap 10, afbeelding 2 van 2
    • Remove the palm rest from the laptop.
Conclusie
Nathan Barganier
97 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 1,496
