Ga door naar hoofdinhoud
Lenovo ThinkPad T400s CMOS Battery Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T400s CMOS Battery Replacement, Keyboard: stap 1, afbeelding 1 van 2 Lenovo ThinkPad T400s CMOS Battery Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Remove the Phillips #0-6mm screw.
    • Lift up the back cover to the RAM cards.
  2. Lenovo ThinkPad T400s CMOS Battery Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad T400s CMOS Battery Replacement: stap 2, afbeelding 2 van 2
    • Pull the lock for the baterry to the left to unlock.
    • While holding the tab in the unlocked position, remove the battery.
  3. Lenovo ThinkPad T400s CMOS Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the three Phillips #0-6mm screws on the back panel.
    • These screws are marked with a keyboard symbol next to them.
  4. Lenovo ThinkPad T400s CMOS Battery Replacement: stap 4, afbeelding 1 van 3 Lenovo ThinkPad T400s CMOS Battery Replacement: stap 4, afbeelding 2 van 3 Lenovo ThinkPad T400s CMOS Battery Replacement: stap 4, afbeelding 3 van 3
    • Turn the computer over and open the lid.
    • Wedge the small metal spudger between the palm rest and the keyboard.
  5. Lenovo ThinkPad T400s CMOS Battery Replacement: stap 5, afbeelding 1 van 3 Lenovo ThinkPad T400s CMOS Battery Replacement: stap 5, afbeelding 2 van 3 Lenovo ThinkPad T400s CMOS Battery Replacement: stap 5, afbeelding 3 van 3
    • Lift up the keyboard, but be careful not to completely remove.
    • Don't lift the keyboard too quickly, there is a connector cable you must disconnect first.
    • Wedge the small plastic opening tool underneath copper band and tilt back.
    • Remove keyboard to replace.
  6. Lenovo ThinkPad T400s CMOS Battery Replacement, CMOS Battery: stap 6, afbeelding 1 van 1
    • Gently pull the back-up battery from underneath the front panel.
  7. Lenovo ThinkPad T400s CMOS Battery Replacement: stap 7, afbeelding 1 van 2 Lenovo ThinkPad T400s CMOS Battery Replacement: stap 7, afbeelding 2 van 2
    • Pull on the black connection piece and remove the back-up battery.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Morgan Montalvo
652 Reputatie
3 handleidingen geschreven
Cal Poly, Team 6-18, Maness Spring 2015 Lid van Cal Poly, Team 6-18, Maness Spring 2015
CPSU-MANESS-S15S6G18
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 53
Altijd: 21,220
