Ga door naar hoofdinhoud
Lenovo ThinkPad T14 Gen 3 RAM Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T14 Gen 3 RAM Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to loosen the seven captive screws securing the back panel.
    • The screws are captive and will not come out of the panel.
  2. Lenovo ThinkPad T14 Gen 3 RAM Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad T14 Gen 3 RAM Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad T14 Gen 3 RAM Replacement: stap 2, afbeelding 3 van 3
    • Insert an opening pick into the seam between the back panel and chassis.
    • Slide the opening pick around the perimeter of the device to release the clips that hold the back panel to the device.
    • Remove the back panel.
  3. Lenovo ThinkPad T14 Gen 3 RAM Replacement, Battery: stap 3, afbeelding 1 van 2 Lenovo ThinkPad T14 Gen 3 RAM Replacement, Battery: stap 3, afbeelding 2 van 2
    • Use a JIS #1 screwdriver to remove six M2 x 5 mm screws that hold the battery in place.
    • There is a risk to your laptop if the battery is not discharged properly.
  4. Lenovo ThinkPad T14 Gen 3 RAM Replacement: stap 4, afbeelding 1 van 3 Lenovo ThinkPad T14 Gen 3 RAM Replacement: stap 4, afbeelding 2 van 3 Lenovo ThinkPad T14 Gen 3 RAM Replacement: stap 4, afbeelding 3 van 3
    • Slide the battery from the battery connector and remove it.
  5. Lenovo ThinkPad T14 Gen 3 RAM Replacement, RAM (Random Access Memory): stap 5, afbeelding 1 van 1
    • Lift the plastic covering the RAM stick.
  6. Lenovo ThinkPad T14 Gen 3 RAM Replacement: stap 6, afbeelding 1 van 3 Lenovo ThinkPad T14 Gen 3 RAM Replacement: stap 6, afbeelding 2 van 3 Lenovo ThinkPad T14 Gen 3 RAM Replacement: stap 6, afbeelding 3 van 3
    • This device is missing the RAM.
    • If you do have one gently pull the metal clips on each side to disengage the clips holding the card.
  7. Lenovo ThinkPad T14 Gen 3 RAM Replacement: stap 7, afbeelding 1 van 1
    • Slide the old RAM from the slot.
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 andere personen hebben deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 74
Afgelopen 30 dagen: 330
Altijd: 3,101
